Ramair
Thread starter- Joined
- Oct 14, 2006
- 9
Hi, I have a Merc 20hp 200 which is a 1978 I believe ser#7061406. I'm looking for some advice on it. It's been difficult to start and when if finally starts to run the idle is erattic. I've played with the low speed screw to try to get a good idle but just can't dial it in.
I just did a total Carb rebuilt/clean. Jets gaskets etc. after reassembling the carb I tested to spark and noticed that the top plug (#1) was intermittently firing then seems to not fire at all. The bottom ply fires consitantly and strong. I tested the ign coils as per manual and they test ok. Plugs and plug wires are ok.
So, my question... should I pop the flywheel and test the stator/trigger etc or look at the switchbox as possible remedy.
Also, seems alot of parts for this engine are N/A. Are there any aftermarket parts places to source ignition parts?
Any ideas/suggestions would be greatly appreciated.
