power loss
boba.
my 50 hp johnson jet falls flat on its face when trying to exceed 4,000 rpm, the engine runs good at idle and low rpm . if i use the enricher the engine runs good for a few seconds. both carburetors have been rebuilt and the linkage and sparkplugs are ok . anyone have any ideas?
JUSTINTIME
Re: power loss
u say after 4000 it just stops
try timing or the high speed is not set right
OBJ
Re: power loss
If when you hit the primer and the engines rpm's rise above 4K.....sounds like to me you've still got dirty carbs or you have an air leak in a fuel line.
Edit: Have you tried squeezing the primer bulb at 4k to see if the engine will pick up?
ob
Re: power loss
This is a duplicate thread.I bumped the original one up.
