1991 force 150
Bradforce
I have a 1191 FOrce 150 with an overheating problem. I have replaced the water pump kit which included new impeller and gaskets. Seems to pump water with hose attached but not adequitly enough and when boat is at the launch in the water it overheats quickly and doesn't seem to pump. Has a new thermostat-took thermostat out and flushed out with hose-water ran freely with no obstruction. Any ideas, please help!!!
roscoe
Re: 1991 force 150
Are you sure the key was replaced in the impeller when assembling?
IS the water tube connected?
Worth dropping the unit to inspect it.
