Manipulator
Thread starter- Joined
- Apr 11, 2005
- 743
I had to remove my motor mounts to rebuild me trim rams. In the process I found a few of my lags just spun due to some rot in my stringers. A few holes were a little wet but not saturated. This could be trim oil that was leaking out of the rams and ran down the lags. A few of the other holes are fine. My question is this, I do not want to rip the stringers out as I believe they are not all rotten. Is there a way to fix this? I was thinking of injecting epoxy resin into the holes to fill the void and then once hard just re-drill the holes. Or should I screw the mounts in while the resin is not set? I do see a reason that I would have to remove the mounts again. The rubber dampers are perfect and the rams are rebuilt. They made it 20 years and probably would make another 20. So if the mounts can never be removed again its not a problem. I figure down the road I will have to have the motor rebuilt and sterndrive. When that happens I will cut out the stringers as it will be a whole lot easier to do with the motor out. Any ideas? What about the product called get rot?
