roscoe
Thread starter- Joined
- Oct 30, 2002
- 21,980
Hi guys.
History:
I bought this little 16' Alumacraft a month ago. 2 bench seats, and a single seat console helm. Book says it weighs in at 380#. Rated for 65 hp !! !!
Total weight boat motor batts fuel gear, and me = 1000#.
It was powered by a 1977 Evinrude 35 hp. I replaced the damaged prop with a "stock" 10x13p and brought the rpm up from 4300 to 4700. Then I raised the motor 3 inches and got the rpm up to 5100 at 28+ mph.
Problem:
I really needed power tilt for my back and shoulder.
Solution:
I bought a 2001 Mercury 50 hp 3 cylinder 2 stroke with power tilt and trim.
And the engine is rev limited to 5700 rpm.
Question:
Where do I start to prop this new motor?
Boat, new motor, batts, gear, bigger fuel load and me = 1100#.
I went to the Merc site and punched the info into their propfinder program.
It recommended a 13p prop. Doesn't seem right.
If the old 35hp and a 10 x 13p prop is right.
Then shouldn't the 50 hp need a 10 x 17p or maybe even a 10 x 19p?
I realize I may need to buy a second prop, but I want to be close with the first purchase.
Your thoughts on a starting point?
History:
Problem:
Solution:
Question:
