AguaSki
Thread starter- Joined
- Jul 4, 2005
- 545
Boat was running great until the end of the day. The channel of the lake I was in had a layer of saw dust looking stuff floating on the water. While cruising, after leaving the saw dust area, I noticed that my water pressure was about 4-5 psi when it is normally 10 psi. About the time I noticed the water pressure change, I entered a no wake area so I eased off the throttle. Then I noticed my motor was not running well. I turned off the engine and looked around, but did not find anything. The motor fired back up, but was still running poorly. I turned around and got out of the no wake area and hit the throttle, but I could not get above 2,500 RPM. Fortunately my bro. in-law was with me and towed me back to the ramp.
When I got home I tested compression. Still 120 psi on all 4 cylinders. I started reading my Clymers manual and learned about a S.L.O.W. circuit that is activated when engine temps reach 203 degrees. Once activated the engine cannot exceed approximately 2,500 RPM. The S.L.O.W. circuit is deactivated when the engine temp is below 162 degrees and the engine is restarted. In my case, I never tried restarting and let my bro. in-law drag me in.
My theory is that this saw dust stuff ruined my impeller. The damaged impeller caused my engine to get too hot and activated the S.L.O.W. circuit, which is the reason I could not rev to higher RPMs. Does this make sense? The fix is a new impeller?
Additional information:
I am really new to outboards and not that mechanical in the first place.
1978 Johnson V4, 140 hp. Can't tell for sure from my manual if my exact engine is equiped with the S.L.O.W. circuit, but I believe it is.
1978 Glastron SSV-188
No temperature gauge, but I do have a water pressure gauge
Never heard the overheat alarm, and I tested it to be sure it works.
Please offer your thoughts on the diagnosis, and remedy.
