david r. lubinski
- Aug 27, 2006
- 4
Could use some advice was what to check next. Heres what I have 120 l/0 in 20 foot bayliner. Cannot obtain rpm higer than 2800revs when underway. Heres what I have done, new gas in tank. Checked fuel delievery system, all new fuel hoses, checked fuel tank pickup it is ok, new fuel/water seperator,new fuel pump with new pump filter, new strain screen at carb. New plugs gap.032 new points gap.022.checked advance weigths they are free and clean, new rotor and cap new wires, verified correct firing order, timming set at 8 degrees btdc at idle 850revs.,36btdc degrees at 4300revs in neutral at dock, new remanufactured carb, compression is 125psi. in each cylinder with cold engine, install new 15x17r prop. new gimble bearing, new u-joints Test are done with only one person aboard boat bascially bare Engine runs excellent at dock but test runs can only obtain 2800revs Outdrive is pre alpha, no unusual noise from outdrive. Hull is clean no marine growth. Sure would like to solve this problem
Engne is 4cyl. G.M. 153cu.in. engine.
