1979 spirit/suzuki 85 hp trouble
jmadoche
i have an 85 hp spirit 3 cylinder and its not running on all 3 once in awhile it will but 99% of the time not and when i take and spay fuel in the center carb. it picks up and runs fine. cleaned the carbs. problem still exist's fuel filter is clean gas is good bowls of the carbs were clean im going to try to replace the fuel line from the tank to the engine. what else could be causing me the trouble?
JB
Re: 1979 spirit/suzuki 85 hp trouble
Most likely an unsuccessful carb cleaning, ima.
It is essential that all tiny passages are cleared. Someimes it requires running a wire through the smaller ones, particularly the passages into the carb throat.
Good luck. :)
deejaycee_2000
Suzuki's carbs are sensitive ... like JB said, you need to soak in carb cleaner for 24hrs and blow out with compressed air ....
jmadoche
carb was soaked in a hot tank boiled out and cleaned blown out and every little hole was cleaned. i watched the guy do it but i wasn't there when he put it back together and synced the carbs unless he screwed that part of it up
