tow hook attachment
bandit86
Banned
I bought a proper ss hook to tow a tube, but I'm not familiar with fibreglass and I dont know if it's strong enough just top attach to the fibreglass or if i should get a piece of plywood or 2x4?
it's a 24ft 87 bayliner cabin cruiser
Chunder06
Re: tow hook attachment
I would bolt it through the hull and onto a ss backing plate of about 75mmX75mmX6mm with some silicon sealer around the bolts.
skibug
Yep, need a backing plate of some sort. The fibreglass is not strong enough for a ski eye or cleat etc... Mount it through the backing plate. Do not simply screw it in.
Bandit, You will need to bolt it to the boat with some sort of backing plate. I would use solid pressure treated 1X4 or some SS, Aluminum or brass plate of say 4X4X3/16"
mole2
You will need a backing plate. It can be stainless steel, aluminum or wood. But you want it to spread the forces out over a wider area than just a nut and washer. Here's a link to the installation I did on my 2005 Trophy 2052. Of course this is a recessed hook but the idea is the same with the backing plate.
Installation of Attwood Tow Hook on Trophy 2052
