kkuhia
Thread starter- Joined
- Jul 15, 2006
- 49
I've never done a compression test, but I've read my service manual and also read the last year's worth of posts on compression testing on iboats. I still have a couple of clarification questions. Here is what I've gathered is the correct step-by-step approach with my questions embedded (my engine is a 1987 4 cyl Volvo Penta AQ131A with Volvo 275 outdrive):
1 - Get compression testing gauge (got mine from Shucks for $40)
2 - Remove ALL sparkplugs
3 - Activate KILL switch (by pulling lanyard)
Question: Do I need to ALSO ground the plug wires as many posts say to do or just use the KILL switch?
4 - Screw in compression gauge into cylinder 1
5 - Push in button on throttle control lever (so drive is not engaged) and push lever forward to full throttle (WOT)
6 - Turn engine over (using key/starter) 7 to 9 times
Question: My boat is not in the water, so do I need the muffs with the hose on to do this?
7 - Write down highest compression reading for cyl 1
8 - Remove compression gauge and screw into cyl 2
9 - Turn engine over 7 to 9 times
10 - Write down highest compression reading for cyl 2
11 - Remove compression gauge and screw into cyl 3
12 - Turn engine over 7 to 9 times
13 - Write down highest compression reading for cyl 3
14 - Remove compression gauge and screw into cyl 4
15 - Turn engine over 7 to 9 times
16 - Write down highest compression reading for cyl 4
17 - Compression readings for all cylinders should be within 20 to 30 psi of each other
Question: I've read a couple posts where people have put the compression gauge in too far (and damaged their heads) or too tight (stripped spark plug hole threads), how can avoid doing this (how tight do I have to screw in the guage)?
Please correct any steps that I have wrong, and thanks for the help!
