Need help finding a part (95 150 Intruder)
dean1969
I need the bolt/bushing that connects the forward/reverse linkage cable to the shifter inside the control box. Sometimes it grinds when in reverse and sometimes it doesn't. I pulled the control box apart and it looks like only half of the bolt/bushing is there. I can simply lift it out with my hand. Being that this is loose will certainly cause the problems I'm having. The control box is OMC, but I don't know what year it was made.
emdsapmgr
Re: Need help finding a part (95 150 Intruder)
If your control box is the same year as the engine, the clevis pin you need is 323776. See your Bombardier dealer. Under $ 9.
dean1969
Thanks -- thats it! One question though...Is there some sort of clip that holds this pin in place. My local dealer couldn't find one.
rickdb1boat
Don't see one. #12 is the clevis pin....http://epc.brp.com/default.aspx?brands=ej&lang=E ] BRP Wbsite[/url] (Listed under outboard accessories
in the drop-down box) I think once the lever swings up, it cannot possibly come out...
convert
dean1969
convert
Ahhhhh, now I get it. It's held in place by the nylon plate (#63). Thanks for the diagram!
