fuel mix ratio
Micko
I'm getting confused about the proper amount of oil to unoxygenated gas is correct for my 95 25 hp Evinrude.
Is it 8 oz to 6 gallons or 4oz. to 6 gallons. What is the proper ratio? Mick
OBJ
Re: fuel mix ratio
50:1....which is 16oz oil to 6 gal of gas.
funpilot
Re: fuel mix ratio
Micko,
The math works like this:
six gallons times 128 oz/gal is 768 oz. of gas.
at 50:1 you need to divide the 768 by 50 which equals 15.36 oz, which is close enough to 16 oz to not matter. Basically, it means that
768:16 is approximately the same as 50:1
So, of course (as always!) OBJ is 100% correct. By the way, 16 oz is half a quart bottle.
fp
Xcusme
Re: fuel mix ratio
Sometimes it's easier by knowing how much oil is needed per gallon at a 50:1 ratio.
1 gallon = 128 oz.
desired ratio 50:1
128 divided by 50 yields 2.56 oz. of oil per gallon of gas.
3 gallons= 3 times 2.56 = 7.68 oz oil (8 oz's is good)
6 gallons= 6 times 2.56= 15.36 oz oil (16 oz's is good)
You get the idea.....(i hope)
