1960 Merc200 22 HP Gas to Oil Ratio
kramer9802
Anybody know the gas to oil ratio for a 1960 Merc 200 22hp outboard? I am going to order an owners manual, but I wanted to know so that I could take my boat out this weekend. I just got it last weekend.
Also is it ok to use Lower Unit Gear Oil instead of grease?
Thanks
Kramer
JB
Re: 1960 Merc200 22 HP Gas to Oil Ratio
I believe that it is 50:1, kramer.
tashasdaddy
not knowing for sure, i'd go 24-1 until i was sure.
Laddies
Banned
Any Mecrury built before 1964 is 24 to 1 if its not black it's 24 t0 1
tashasdaddy
thanks for verifying ,
Motor Boater Bill
Bob Grubbs told me it was OK to use 50:1 TCW-3 in my 1962 Merc 110. The 1960 may be a different deal. I'd suggest contacting Grubbs. If you get a manual original to your motor, it will not give you the definitive answer, since the manual will have been printed prior to the development of modern oils. The oil recommendation, as I understand it, depends on the formulation of the oil (new oils are far better than the oil was when your motor was built) and the internal design of your engine--specifically whether it has bronze bearings or needle bearings. Bronze bearings require more oil.
This information has been gleaned from reading many posts on this topic, including the FAQ's on this site. I am not a qualified engineer or technician, just passing along the results of my own research. You will find the experts do not all agree. In broad strokes, more oil than recommended can cause more smoke, plug fouling and possibly more carbon buildup. Less oil than recommended can cause horrible damage. Obviously, to take it out this weekend you'd want to err on the side of safety while you figure out what's best for your motor in the long run. And if the motor hasn't been run for a long time, extra oil may be a good idea to get the innerds all lubed up.
