1968 35 hp merc wont pee and runs real rough
dafooge
i got the new starter in all the wiring was brittle so i taped it up. put it in a tub of water way past the inlet holes on the lower unit,,it burped and pharted then ran rough for a bit, as all this was going on it wasnt spitting any water thru the outlet. the motor ran for 2 to3 mins or so and it got a little hot so i shut it down,,my question is , where is the pee hole on this 1968 merc 35 hp twin be? shouldnt i see the water streaming out? also it sat in a barn for a few years, should i go right thru it points condenser etc? impeller kit? thanks dave
tashasdaddy
Re: 1968 35 hp merc wont pee and runs real rough
email me since the faq is down, will send you awakening a sleeping outboard. it will get youon your way. yes you need and impeller,carb kits. lower unit oil, at least it runs.
tashasdaddy@comcast.net.
Fishing_Victim
Ok im sorry for stealing your thread but im having the same problem with a 9.9 horsepower outboard i cleaned the carb and now it finally runs yet rough but it still doesnt pee
tashasdaddy
should start you own thread, no pee, replace impeller and if it has a thermostat that also. a 9.9 is not a very good description. there's lots of them. try runing some weed eater string or the like (ouch) up the pee hole, insects like to nest there.
