Seadoo 1996 GTX impeller
mjjrkb
I need some help on how to replace my impeller on the GTX. Also where is the best place to buy one and what type?
Jeff Walkowiak
Re: Seadoo 1996 GTX impeller
take the pump off take the cone off hold your nose because the lube stinks bad, use the sea doo impeller tool and a 3/4 in socket with a breaker bar and unscrew it from the impeller shaft, replace the liner while you are in there, I use a big soldering gun to melt a small line through the liner and just before it cuts through stop and use a big screwdriver to pop the liner , get a white liner if you can and place a 2/4 over it to carefully tap it in place. I usually just clean up the leading edge of the impeller straighten out any dings and use the same one.
if you find water in the pump you need to replace all the berrings and seals that's another story
CaptnKirk
Solas makes a variety of impellers for your ski along with Skat-Trak. You didnt mention the engine size so I cant tell you the best pitch. Also, what are you looking for, performance wise? Better holeshot, hookup or top end?
Captn---
