PROP WIZARD NEEDED
bowlin257
I bought a 1984 35 HP 2 cyl Mercury. The prop is frozen on the shaft and I expect to wreck it getting it off. I can find no numbers on it except "13" which I suspect is the pitch. Mercury shows 6 props for this motor with part numbers 48-731XXXXX pitch 10" to 17". For a 14 FT. boat I think a middle of the road 13 pitch will be fine. In looking on ebay, I find 13 spline props in the 10 to 11 inch dia. 13" pitch but the number don't match my list Whats the deal on these, will only the parts mercury list for this motor fit?
JB
Re: PROP WIZARD NEEDED
Prop wizards are to be found on the Props Forum.
gatorred
my 35 has 11,13and 15 in pitch i have four prop and two blade one that is either a 13 or 18 very hard to read they all fit my 50 too.
Dhadley
Is your shaft a 13 spline? Or is it the props youre looking at are 13 spline? <br /><br />We need a spline count on your shaft.
walleyehed
84-89 35's all use 13 spline of the same diameters and hub size...<br />1980-83 there was no 35 so I think you spline count "should" be 13.<br />I don't know if there are even props available for 1970-back for the early 35's...<br />MWC may have some.
gatorred
I have prop's for my 35 and 50 I was going to run it little if any maybe sell the whole boat with both motor's
bowlin257
spline is 13, from what I can find factory prop for this motor is 10.25 to 10.75 diameter, 11 to 17 inch pitch. I would think any 13 spline, thru hub exhaust, 10 to 11 inch prop would work??? the prop that came on it is froze on the shaft. I expect to have to torch it to get it off. Been soaking in Kroil for several days with no luck.
gatorred
No links allowed, Gregg....we sell props right here.<br />Mod1<br />sorry
walleyehed
bowlin257, not just "any" 13 spline will work...each is designed for a particular manufactures prop-shaft, although the shaft size may be the same, the prop hub is not. Thrust and aft washers are different, and blade design is built to be used in a particular fasion on a given engine.
