95 GMC transmission Update
Boomyal
Re: 95 GMC transmission Update
Originally posted by Bondo:<br /> RP,.....<br /><br />Just for Ss & Gs,......... Try the Cold Water thing,.................<br /><br />You Won't Believe It................. I Didn't,.......... Til I Tried it Many Years Ago......... ;)
Bondo, could you elaborate?
Ron G
(Heat the Broken piece to RED Hot,+ Quench it with Cold Water,.......<br />It'll turn out with little more than Finger Pressure..................<br /><br />Probably need Oxy/Ac to get it Hot enough though..........)<br /><br />Im going to try this on them nuts if i can get up inthere without burning something up.
That pretty much says it All.........<br /><br />On a Cast Iron Manifold,.......<br />I'd use a Smaller than normal tip,+ try to heat Only the broken piece,...<br />'Course that can't happen, but Most of the heat Will be in the Stud,......You'll be pretty much Melting the Edges.......<br />Then Quench it......<br /><br />On something Steel,.... Exactly Where the Heat goes is of Less Concern...<br />But it Works the Same Way.....<br /><br />If there has to be any Drilling,.. like for an Easy-out,.... Do it 1st,.... After the Quench, it's Too Hard...<br /><br />After the Quench,... Blow off the excess water,+ Bathe it in your favorite Slippery Juice,+ It'll Almost Fall Out..........<br /><br />I've done 15 year old Exhaust Clamps,.... That didn't even Look like Nuts anymore.......... ;)
Reel Poor
Ive done that on bearing races.....ya know the ones in a hub without a cutout to knock the race out. Heat the race red, then turn hub upside down, then douse with water the race will fall out.
Ayuh,.......<br /><br />Or,... Weld an inch of Bead on the inside face of the race,...........<br />Stick or Mig both work........<br />It'll Just Fall Out in a minute.....<br /><br />It's a Good Way to get a Pocket Bearing out of the end of a Crankshaft Too........<br />The Welding I mean......
Ron G
Okay got busy fishing and working,i finally got the money and my new transmission is in,and clutch kit,and throw out and i got a real seal,i dont know weather i need it or not,the old transmisssion is already to drop out this afternoon all i got to do is put the jack under it and loosen the 6 bolts.i could'nt find a manual at our stores with what i need in it so a maybe asking for alot help here.<br /> Never could get the torches up in there i was afraid of burning myself,but after days of spraying with yeild and a couple busted knuckles the studs came out.<br /> And why do they put 2 differnt size nuts on the transmission for all the wiring harnesses :mad: Thanks guys.
Ron G
Also what type of oil should i use?just regular transmission or something special?
Ron G
Finally got the trans out,i feel like ive been beat to death this morning.pulled clutch assembly out and removed the flywheel,well while i was that far i pulled the rear seal out,now i had to romove the last 2 bolts of the oilpan,do i need to remove the entire oil pan or can i just put a new rubber gasket on the lip of it?and when i put the reseal back in do i need to lube it with anything?
Reel Poor
What size engine and how many speed tranny in the 95 GMC truck?
Ron G
Thanks RP,305 5 speed ,i ended up dropping the oil pan put a new gasket on it,i installed the real seal,and installed the flywheel,found out the pilot bearing is pressed into the crank,so removed the flywheel.so how do i remove the pilot bearing out of the crank??<br /> Weres everbody been??Surly the little bit of Drama in the basement hasnt effective here has it?
Reel Poor
You can probably borrow/rent a pilot bearing puller from a local parts house or if you find a steel rod that will JUST slip into the pilot bearing, you can pack (and I do mean PACK) the bearing hole full of heavy grease, then place the rod into the hole and hit the rod with a hammer, repack the hole with grease, hit rod with hammer, pack the hole with grease, hit the rod with hammer, pack the hole with grease, hit the rod with hammer, and keep repeating until bearing comes out. The grease wont compress, so everytime you pack more in with the pressure from the blow of the hammer eventually the hole will become so full of grease that the bearing will be forced out by the pressure of the grease behind it.<br /><br />Your tranny uses a special lube called Syncro-Mesh, avaliable at your local GM dealer.
Ron G
Thanks RP i'll try that grease thing.
Reel Poor
Don't just tap it with the hammer, knock the he!! out of it, and the rod should juuust fit in the hole, if its to small it won't work.<br /><br />BTW Hope to see ya at Grayson Lake. So get that puppy running and come on. Bring the wife, mine will be there. :)
Ron G
Going to try my best!
Ron G
They gave me 4 quarts of synchromesh,i put 2 in and it started running out the side of the fill hole.is 2 quarts enough???
Ron G
It took a little over 2 quarts.finnally got it all back togeather and the slave cylinder was shot :mad: got a new one and put it in.went for a test run with just the manifolds,for some reason its not real smooth going into first gear and a little tight threw the others??I bleed the slave cylinder 5 times,maybe i was just use to a wore out clutch and tranny????
Ron G
Got her all back togeather and already put over 100 miles on it.ended up with flowmaster duals with 3"tips,sounds real good and seems to have a little more power too.<br /> Thanks for all the help guys.
