tell tale
scotty c
My Bf50 does not have a lot of pressure out of the tell tale.<br />it definitely squirts water, but not sure if<br />there should be a lot of pressure ??<br />i have seen some motors that will squirt a 4'<br />stream.<br />is this an indicator the water pump is working <br />better?
scotty c
Re: tell tale
further to this, if anyone has same problem..<br />grab a can of compressed air from a computer<br />store.<br />put the nozzle up the pee hose with the motor<br />running and blast away<br /><br />it cleared the blockage with a few blasts<br /><br />now squirting water better than ever !
gss036
Re: tell tale
A piece of .80 weedeater string works wonders also. It is flexible and will go all up the tube.
