I have the model # but where is the serial#
jtp7571
Can some one help me find the serial # for this 1990 90hp Force? It'a Model 90-GX90C. I have found some numbers on the engine and they are:719518 & m839837. <br />Are either one of these it? The transom bracket has been chainged so it is not there for me to get that information from.
roscoe
Re: I have the model # but where is the serial#
The only place the serial number will be is on the id tag on the transom mount. Your model number is actually 906x90c. Thats a six 6 , not a g.<br /><br />The serial number for your motor should be 4 digits. (like 1137)<br />It means nothing, as all identifying info is in the model number for your motor.<br /><br />If you had a newer motor, the serial number would be similar to OE023123, and would be used to determine the year.<br /><br />If you need a serial number for your insurance company, pick one and give it to them. I like the m839837 number.
jtp7571
Thank you Admiral. That was why I needed that information. I did not know the "g" was actualy a "6" and now the Model # makes since.
