The other day while out on the river after about an hour or two I lost my reverse on a 1994 Force 40hp it made a grinding noise when the motor was put in reverse. The forward still worked fine.<br />After getting it home I checked it out and found that what looks like a seal behind the prop was broke where the bolts hold it tight to the lower unit. Upon further inspection I also noticed that the fin on the bottom is cracked up through the bolt holes as well. I understand this is a major problem (expenseive) so I'm trying to find out what years and what hp motors are compatible with mine which is a 1994 Force 40hp.
