92 FORCE
rcollins
DEALER TESTED MY MOTOR AND SAID IT HAS 50 ON EACH CYL.WHERE DO I GO FROM HERE?
roscoe
Re: 92 FORCE
What model motor do you have? hp?<br /><br />I would start by pulling the head and examining the head gasket, head, pistons, and rings, looking for damage.<br /><br />Could it just be a head gasket? Maybe, probably not, you will only know if you look.<br /><br />If motor requires a total rebuild, it is not worth the time or money.<br /><br />Better to put the money toward a decent late model used motor.
roscoe
Re: 92 FORCE
The cost of a total rebuild would be in the 1400 to $2000 range.<br />Some probably better to part it out on ebay and look for a new or late model used motor.<br /><br />But check the head/gasket/pistons before deciding what to do.<br />Might only be a $100-$200 repair.
rcollins
Re: 92 FORCE
THANKS ALOT FOR YOUR INPUT.I AM WORRIED ABOUT BREAKING THE HEAD BOLTS ,ANY ADVICE,THANKS RCOLLINS.
fixin
Re: 92 FORCE
Did the motor run? What happened? Do you trust the dealer?
rcollins
Re: 92 FORCE
THE MOTOR RAN GOOD,IT GOT WHERE IT WOOD IDLE GOOD BUT WHEN I PUT IT IN GEAR IT DIE,SO I TOOK MY TIME ,BUT FINALY ,I HAD TO PUT IT IN WARM UP AND THEN CRAM IT INTO GEAR IT WOULD RUN FINE,THEN ONE TIME IT QUIT.THANKS AGAIN
olowiany
Re: 92 FORCE
sounds to me the thing is out of time check the half moon key under the fly wheel
12Footer
Re: 92 FORCE
Rcollins, it could be a blown head gasket, so do pull the head and inspect it.<br />Low compression will cause the symptoms you describe with poor idle, sooth running, and low HP. <br /><br />Did the motor overheat?
rcollins
Re: 92 FORCE
I AM TEARING IT DOWN,BUT I CAN'T TELL IF ITHAS 5 OR 6 BOLTS HOLDING THE POWERHEAD TO THE LEG.ANYWAY I'LL LET YOU KNOW WHEN I FIND OUT.IF ANYONE KNOWS PLEASE TELL ME.THANKS RCOLLINS
roscoe
Re: 92 FORCE
Can't you just remove the head without removing the entire powerhead?<br />Maybe not. Haven't looked at one of those in years.
rcollins
Re: 92 FORCE
I AM PULLING THE POWERHEAD,BECAUSE I BROKE THREE BOLTS IN THE HEAD.I FIGURE I CAN WORK ON IT BETTER IF I TAKE IT OFF.I CAN PUT IT ON MY DRILLPRESS.BUT I CAN'T TELL IF ITS GOT 5 OR 6 BOLTS ON THE BOTTOM.THANKS RCOLLINS
fixin
Re: 92 FORCE
MY Man. doesn't show or say but says "remove bolts holding the powerhead including the two 12 point fasteners in the front adjacent to the upper cowl shock mounts"
rcollins
Re: 92 FORCE
WELL I GOT THE POWERHEAD OFF,BUT I HAVE BROKEN 5 HEAD BOLTS.ANY SUGGESTIONS ON HOW TO GET THE HEAD OFF?ALL REPLIES APPREATED!THANKS RCOLLINS.
rcollins
Re: 92 FORCE
I finally got the head off,but I ruined it ,I found a used one.Its an 89 not a 92 .Anyway I need to know if I can use stainless steel bolts for the head instead of the regular ones.
