1984 chrysler 90 hp.Tilt and trim fill
barefooted
watt postition should i have my motor to check TnT fluid ? Is full up the correct position?
CHARGER
Re: 1984 chrysler 90 hp.Tilt and trim fill
Im not sure exactly but how I did it was had it at full lowered position checked it and found it too be down filled it then moved it up and down a bit and filled it more till it was full after tilting up and down.
Oldsaltydog
In the case of my 1998 90HP, the motor has to be up to check the level. There is even a warning label on there about the danger of doing it otherwise -- spillage under pressure.
barefooted
Thanks for the helpers. Think they got it all figured out.
