Pulling Flywheel 6 HP Chrysler
G DANE
I'l have a look at ignition part on an old ( 1974 ) 6 HP Chrysler twin. What do I use to pull flywhell. It has no holes for a balanced puller, only the center nut. Brakedrum Puller ??
scotiany
Re: Pulling Flywheel 6 HP Chrysler
Whatever you do, don't attach anything to the teeth of the flywheel.
G DANE
No I wount.<br /><br />But there must be an authorized way to do it - I´d like to avoid ruining anything. I looked wrong at the hood, its a 5 HP.
eurolarva
Manual says to insert a large screwdriver between the flywheel and top of power head at the rear of the engine. Loosen the nut holding flywheel but do not remove it. While prying up on screwdriver tap on knock off nut with a 16 oz hammer untill it pops loose.
