fishthebay
Thread starter- Joined
- Aug 17, 2001
- 180
Hello:<br /><br />Thanks for everyones help on walking me through dropping the lower unit and replacing the waterpump. Everything seems to be A-OK with the waterflow, but I did run into a thermostat problem.<br /><br />My housing has 4 screws. The bottom one on the right broke off. I drilled through the bolt and put an easy out on it. When turing the easy out with a wrench that broke off too. I tried drilling that out but absolutely no luck.<br /><br />I smoothed it out by lightly tapping it with a hammer, gave up and then just used the 3 bolts that weren't broke to install the housing over the new thermostat, grommet and gasket.<br /><br />I fired the boat up on muffs to check my waterpump job, let it idle for at least 15 minutes and the the water flow was strong and no leaks around the thermostat housing.<br /><br />Am I OK? Leave it alone or pull that thing what I believe is called some type of head and get another?<br /><br />Suggestions Please.
