5hp Chrysler outboard water pump
Water Bug
This older motor-tag ID# Chrysler MOD 54BB<br /> Canada Outboard LTD SER 2165<br /> Barrie ONT. CAnada<br /> 5BHP at 4750 RPM<br /> Full power speed range<br /> 4250 to 5250 RPM<br />Sat for long time found points all closed up and yuky(Dual type on turning plate device) set both cyl to .020" on top dead center @ full throtlle (found stamp in plate set .020") The beast started right up with old gas that was in tank, a low speed stumble but remarkably empressed it started, now im not sure if the water pump is working or not a very very small mist of water is coming out of top i guess exhaust holes above water line is this enough or is she still a junker all help would be muchly appreciated can a pump still be found and how big a prob to replace thanks in advance. I think there is even a picture of it in chinewalker Sept 21 collection
Solittle
Re: 5hp Chrysler outboard water pump
Suggestions are:<br /><br />1. Get a manual for your engine.<br />2. Under Search at the to of the page enter chrysler water pump (or something like it). Read until you get sleepy.<br />3. Plan on replacing the water pump and rebuilding the carb.<br />4. Do not run it again until you have purged every drop of old fuel in the system and have fresh pre-mix.<br /><br />Good luck,<br /><br />Howard
BHM7952
Have sold the service manual but I have an original parts catalog for your Canadian made 1974 5 HP #54BB It give an exploded view of each component, part name and order numbers. Also includes specifications, lube requirements and special adjustment chart. 14 pages in very good condition $7.50 (includes S/H within the USA.)<br />Email:linda@nu-z.net
harrison20002
Waterbug, the manual you need is Clymers #750.<br /><br />Ditto on purging the old fuel and above all don't run it until you [at least], inspect the water pump.<br /><br />I have a 5hp-6.6 hp and a 9.9hp Chryslers and with a little TLC they all run pretty good. Good luck with yours. Happy Boating. Hal
gateway
Your not going to have a stream of water out the back, Just a slight spitting of water out the exhaust ports.<br />NO4NJNK
