Compression Test
lall
What is a good compression number for 1987 Force 120HP? I am buying a 1987 21ft Bayliner Trophy with this engine on it? I tested it and the motor read 60 across the four cylinders. <br /><br />THanks
wilde1j
Re: Compression Test
What procedure did you use? Warm up engine 1st? Readings are on the low side. Generally, should see > 100 psig all around. Tell us how you got readings.
lall
I took the boat for a test run for about 1/2 hour. When I came back to the slip, I tested the compression.<br /><br />Thanks
Lugnut36
Did you turn it over by hand while checking the compression or did you use the starter?
lall
I used the key to turn it over. I give it a quick turn.
dmessy
Cycle each tested cylinder at least 3 times on a warm engine to get a proper read. Should be around #120 each. No more that 10 percent varience between cylinders.<br />PS- Make sure the sparkplugs are in the wire cap and they are grounded to the block when you turn it over. Also , turn your lanyard safty switch to off position. Failure to do this will fry your ignition system!!!
lall
dmessy, where is the Lanyard safety switch located? Also the engine prop was in water when I did the test and the Spark Plug wires were Disconnected. Should I have the spark plug wires plugged into the other spark plugs as I am doing test on one of the cylinders?<br /><br />Thanks
dmessy
It should be on the control s or very close by. It is the switch that you are suppose to connect to the operator in case you go overboard. When it gets pulled out , the switch will kill the motor.<br />Just disconnect 1 wire at a time, pull the plug, reconnect to that plug, and put the plug in such a position that the metal on it touches the engine housing block securely. Naturally , it will be sparking so watch out for fuel fumes and keep a fire extinquisher very handy.<br />I've checked compression at dockside but you run the risk of dropping your tools in the drink or worse yet, getting your leg smashed by the boat when a wave comes along. A better method would be at home using muffs or better yet a makeshift test tank. Same deal, warm it up and turn it over a few times on each cylinder you check.
lall
Actually, it was not that difficult because the motor lifted pretty high. Another question is that, Can I test the compression with the motor in the tilt position (if that is the right word)?<br />Do I keep the other spark plug wires connected while I am testing one of the cylinder?<br /><br />Thanks for the all the help.
rlouns
I think what dmessy is trying to say is that while cranking the engine for a compression test on this engine you need to have all of the spark plugs out and stuck into their spark plug wires and laying against a ground so that they will spark as you turn the engine over and therefore decreasing the possibility of damaging your ignition system.<br />I have not heard this before so I am not saying this is correct I am just clarifying his statement. ;)
wilde1j
Like Robert said, compression test w/ ALL plugs out. Let us know what results you get.
