85hp Force ignition switch wiring
jrbjr1
I bought this engine from a friend of a friend of a friend and I need to hook up the ignition switch correct this time, last time I burnt my stator and don't like this down time. In the manual I'm to run the switch between the blue and white wires on the terminal block, only there is no blue wire on the terminal block the white wire is there I'm just not sure where the blue wire is to come from.<br />any help is greatly appreciated, Thanks
FORCE10
Re: 85hp Force ignition switch wiring
I just posted a question about the wiring on my Force 85hp
it's a 1988,don't remember if you stated the yr.
i put in a list of where my wires were on the terminal block
coming from the motor,might help you.
post is "17' apachiboa to 85hp Force wiring"
Force10
