Problems while Starting Force 70HP
bitomsky
My Force 70 year of construction 95 goes out in the no-load operation and starts only if one with the black yellow cables at the SWITCH box against ground breaking spark produced. Who can help?
12Footer
Re: Problems while Starting Force 70HP
That wire is for the kill circuit. If the engine wont run without removing this wire from the switchbox, you have a bad ignition or emergency kill switch, or a short to ground of this wire, in the harness somewhere.
