Re: Lower unit won't come out!!
Bluefish is correct. There simply isn't that much play (4") anywhere but the shift linkage. Maybee the water tube is stuck in the pump discahrge flange? But there wouldn't be that much play there.<br />There is a 2" long nut with lock bolts on the shift shaft where it comes out of the leg,underneath the powerhead,on the starboard side.This is where the linkage has to be seperated.
