Re: 85 hp force
I would highly suspect the carbs,Randy.<br />2 years of sitting does mean things to 2 cycle carbs. They should be removed and cleaned troughout. Pay particular attention to the pickup tube,fuel-air mixture and mixture needle ports. Make sure the jet in the side of the pickup tube is clean,and not just open (they're easy to miss, and can really harm performance).<br />Remove the float, and clean the needle and needle seat.<br />Also, while you got the cleaner out, remove the fuel pump filter and clean it with the spray.<br />The fuel pump may require rebuilding, but try it first, and see how the carb cleaning helped. The fuel pump kit is cheaper than the carb kit,tho. The diaphrams in them have a tendancy to rot from sitting and from today's "garbohol" fuels.
