Pulses per Rev
Status
Not open for further replies.
Recieved my new tach today and there is four settings on the back asking for positive pulses per revolution. I've looked in two manuals and done a search for that info here with now luck. Can anyone help on this one?<br /><br />50 h.p. force 88c<br /><br />
MarkC
Re: Pulses per Rev
The tach counts the pulses per minute at the distributor/coil, and divides to get the engine rpm. To get rpm from ppm, divide by the number of cylinders (and then multiply by two if it's a four-stroke, which has two revolutions for every cycle).
Re: Pulses per Rev
Hello MarkC<br /><br />I must be a little slow. Could you explain that again? What am I dividing by number of cylinders?<br />
MarkC
Re: Pulses per Rev
No prob. The "revolutions" are full turns of the crankshaft. With each turn of the crankshaft, each of the pistons goes up and down once in its cylinder. In a two-stroke motor, for every cylinder there is a spark each time the piston goes up; in a four-stroke it's every second time. The cylinders take turns sparking. So either once or twice per crankshaft revolution (depending on two or four stroke) there is a pulse at the coil (initiating a spark) for every cylinder. It's these pulses that the tachometer knows about---so you have to add the info about number of cylinders and two- versus four-stroke to enable it to tell you about rpm's.<br /><br />SO, if you have, say, a four cylinder two stroke, there will be one revolution for every four sparks (pulses). If you have a three cylinder four-stroke, it's a revoltion for each one and a half pulses. If you tell us what the settings on your tach say, and tell us the number of cylinders and two- or four-stroke, we can tell you what setting to use. Most tachs made for auto engines have settings or scales for 4- 6- and 8-cylinder four-stroke engines.<br /><br />In some cases, the tach won't have an exactly appropriate setting, but it makes no difference, because at any setting all you have to do is to multiply or divide the tach's reading by a number. My tach doesn't have a 4-cyl setting, so (for my 4-stroke 4-cyl Mercruiser) I multiply the 8-cyl readout by 2.
BirdChaser
Re: Pulses per Rev
MarkC,<br />I had a question regarding installing a tach on my merc 25 2cyl in a previous thread. <br />In your excellent explanation above, you didn't mention anything about 2 cyl engines.<br />I would assume the math is probably the same. Can you confirm?<br />THANKS!!<br /><br />------------------<br />Find the birds & you've found the fish!
clanton
Re: Pulses per Rev
ON an outboard the tach reads pulses from the stator, under the flywheel, you should have got a sheet of instructions with tach. E-mail or call teleflex. www.teleflex.com.
Re: Pulses per Rev
I have a two stroke, two cylinder. <br />The settings are:<br />Pulses Settings<br />2 1<br />3 2 <br />5 3<br />10 4<br />From your explantion mine should be 2 pulses with a setting of 1.<br />Is this correct?<br />Thank You very much.<br />
Re: Pulses per Rev
Hello Clanton<br />The local shop told me that Teleflex doesn't make that model for a 50 hp anymore so I ordered a Quicksilver. Yes I did get instructions and all but the pulses are fairly simple.<br />
BirdChaser
Re: Pulses per Rev
FYI-<br />I e-mailed teleflex on my application yesterday & got a reply today. The support person gave me the model #'s & the settings.<br /><br />The telflex support e-mail address is:<br />techsupport@tflx.com<br />Be sure to include Make, year, S/N, & # of cyls.<br /><br />GOOD LUCK!
mduncan
I know this is a 20 year old thread, but, I want to thank those here who answered my question. I have rebuilt small block 350s, and 22R 4 cylinder engines, but I was at a loss when my new tach asked me the spark per revelation of my 2 stroke 2 cyl outboard. Plus I'm very green in the world of boats. Thank you all.
jerryjerry05
You don't have to worry so much about pulses on an outboard.
The stators can come with 6 to 20 poles.
Take off the flywheel and count the lugs.
The Forces usually had 20 poles.
The dial on the back usually reads 1 thru 4 (cylinders)
Set yours at 2 cyl. and the poles take care of themselves.
Status
