Ccfbailey
- Apr 18, 2013
- 33
I just purchased a Lund Rebel with a Shorelandr trailer with a swing tongue. Been having a grounding issue with this. There is NO ground secured on the frame. Not from the plug and not at any light. There is ground (white) going to each light. I'm guessing the mfg figures that the ball and hitch is a good enough ground. The dealer told me to rough up the hinge at the swing because of the paint acting as an insulator. It kinda worked. I'd like to ground the trailer properly. Since there is a white wire present at every light, can I splice into it and attach it to the frame? Should I do it at every light or would one spot be enough? Hard to believe a trailer is wired this way.
