Welcome Guest - Sign Up today
  • Dear Community Members,
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change. What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 9/30/2020! The whole transition should take 24-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
Announcement
Collapse
No announcement yet.
The wait is over. Sharrow prop test.
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • The wait is over. Sharrow prop test.
    Been waiting on the first test of this, perhaps some of you have too ??Thoughts ?
  • #2
    Mmm. It seems almost unbelievable!!
    but I’m confused by two things.
    you’d think that set up would require more than a 15” pitch maybe ?
    Im also a bit wondering about the wot and it’s rpm. I’d be amazed if all three props all ran at exactly 5850 rpm wot. I’m sure that engine maybe runs to about 6000 rpm. Need to check if it does.
    wonder what the other 2 props were. The first prop looked like an enertia. The second maybe a tempest or similar ?
    seems a remarkable thing at low planing rpm though.
    Comment
    • #3
      Ok so merc 150 rpm range is up to 5800. So I’m presuming they were taking the wot results on the limiter. Hence the reason for the unusually low pitch for the norm on that set up. Perhaps some foul play here.
      I want a test with the right pitch. Surely that should run at least a 17/19”. I’d say the test has been slightly aimed towards giving the sharrow an advantage ??
      Comment
      • #4
        Might look at this tomorrow when I can listen to a 15 minute commercial. There was another (Merc) prop last year (forget which one) that was spit out as the greatest thing ever. I sent my questions to boattest and Merc but never heard back anything from them. Most always they are commercials and are set up to sell things
        Most of us are told as a kid, to swim keep your fingers together, this is taking a hand and openeing the fingers, or at least that's my first thoughts
        94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
        95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
        07 Seadoo GTX
        Merc Adults Only VP Adults Only
        G-Dad always said "First Liar doesn't stand a chance"
        Comment
        • #5
          Haha.
          Mira a shame but the test has defo been favoured towards it. Why else would you have a 15” prop on that set up and take the results on the limiter. Shame.
          my 115 CT has the same gearbox at only a slight difference in ratio. On a heavier boat too. It runs a 19” to the limiter on that at 6150 rpm. That boat should surely have a 19” on it. I’m calling it not a fair test. The low rpm planing seems good though.
          Comment
          • #6
            All I can say is WOW. Its nice to see a real world test on this prop. Now I wonder how much they will be and available to the masses.
            2004 Caravelle 187
            Comment
            • #7
              Says comparable to others in pricing. Soon see.
              I thought it would be a real world test. This reviewer is normally pretty impartial...but I’m certain this test was tainted by using a considerabley lower pitch than would normally be on this set up. By at least 4” I’d guess. No way a 15” would be normal. Further clarified by the rpm figure at wot. 5850 is on the limiter surely. If it’s not...then equally there is no way all 3 props managed to see the exact same rpm wot as a coincidence
              Comment
              • #8
                It has me fascinated for sure...but adding to my doubt...if I’m right and one of those props is an enertia (sure looks like it. Very distinctive)...at that diameter and pitch...I’m suspecting it’s the enertia eco version. Love to see the test done with the right pitch and up against the top dogs like the proper enertia and tempest plus etc.
                Comment
                • #9
                  Depends on what Merc is using as a Gear Ratio, and the Engine's WOT Range
                  1) There was nothing there that looked like an Enertia. A Solas SS perhaps
                  2) I wonder how this Miracle Prop would fare against Merc's Higher Performing Consumer Props.
                  It is interesting to note the first 2 props were SS and MP was AL.
                  Comment
                  • #10
                    Max rpm on that motor is 5800 of the range.
                    prop 2 really really looks like an enertia or enertia eco. Go to just over 5 mins and pause when he is handling it. It’s defo a merc prop at a min and I’m sure it’s an enertia. Pause it and you’ll see.
                    Comment
                    • #11
                      When I saw the First prop @ 3:26 and 3:29, it didn't look like an Enertia, then @ 5:49 as it is being removed, it does look like an Enertia or a Q3. First time I watched the video, I wasn't paying attention at 5:49. But what they claimed to put on first didn't look what they removed. At 5:53 they claim to be checking Prop #2 before putting it on, but are holding what they just removed. Meanwhile as they speak.the prop they had supposedly installed first was sitting next to miracle prop. Poor editing/continuity of the video maybe. Somewhere they may have run an Enertia or Q3, or at least filmed removal and handling of it.
                      Comment
                      • #12
                        First prop is a Michigan wheel apollo was able to pause and get the part number
                        2004 Caravelle 187
                        Comment
                        • #13
                          Why are people so bent out of shape about this prop? It looks like the testing of a prototype, not production model.
                          Comment
                          • #14
                            The Prop is interesting, but the Video is Pathetic
                            Comment
                            • #15
                              Sign up today
                              Wonder how that would hold up in salt water, might have to do a little more research to find out if all the claims a true, but if it is a prototype then there will no doubt be some changes, very interesting nonetheless
                              The trouble with trouble is it starts as fun!
                              Comment
                              Working...
                              X
