Alpha One Drives
Msorkin
i want to use an Alpha One gen 1 on a gen 2 setup. I know you can't use a gen 2 on one with a gen 1 setup but what about putting the gen 1 on?
Scott06
In a word no won't work. Among other things Shift mechanism is different
matt167
Swap the transom assembly and it will work. Just involves pulling the engine forward..
If your doing it for a cheap drive, SEI drives are only $1,500 new
Ayuh,.... Welcome Aboard,.... Nope, they won't interchange, either way,.....
