My first post at iboats so please be patient! - I've spent most of my time on THT, but I'll start right in with my problem. Just recently purchased a used Pursiut Denali 2860, 2001 - 7.4L - VP Duo Prop. I had the boat surveyed prior to purchase - high moisture reading in the transom, but surveyor felt it was solid based on the hammer tests. Anyway long story short brought it home to Vermont (Lake Champlain), dropped boat in the water getting ready for the season. My yard was bringing it up to temp, when he put it in reverse he saw a fairly heavy leak, forward less so, in neutral little if any.
Bellows is pliable, old but no visable tears - he is worried that putting in reverse is flexing the transom and causing the leak, talked to the surveyor and he doesn't think that could be the case. Obviously we are hoping it is the bellows - but could there be something else? Really don't want to rebuild the transom....going to continue to investigate but was hoping folks might have some ideas. Thanks in advance for any guidance/suggestion that can be offered.
