truckintyler
- Jun 26, 2010
- 77
here are some pictures of what i have done, i wanted to get some of under the flywheel and show the main part but... having trouble getting flywheel off.
i didn't care about keeping it original
Does that SCR have to move much heat? I'm wondering if it would like some heat sink fins hangin' out of the potting material.
Thought the same thing about the current but when the multimeter didn't go negative I guess it was ok.It's my poor neighbor's 9.9, and he really doesn't want to give it up, but I got it a at yard sale for $25, and gave it to him. He's been unwilling for two years to cough the $250 for a CDI replacement stator, and now he has a Johnson 6 hp, so he doesn't need it. I'm going to order these components from Mouser, fabricate the circuits, then I'll go buy or borrow the motor for field testing. He needs some time to finally just give it up, but I think he will. I'll keep ya posted, though, and thanks a million for the parts list and pics. I have seen that article before, but I had no way to tell if the induced current went positive or negative first, so I gave it up.
Also forgot two parts
6 x 1n5408 diodes
And 2x NTC 500 ohm thermistors
Sorry about forgetting those
"A second improvement involves the use of a negative temperature coefficient (NTC) thermistor across the gate of the SCR. This thermistor reduces its resistance with increasing temperature and is used to compensate for the lowered triggering requirement of the SCR (for both voltage and current) at higher temperatures.Thermistors? I don't recall seeing thermistors in there? What do they do? I would expect to be able to get the diodes at the Radio Trash.
