saltybutwet
- Jun 30, 2013
- 197
1993 Mercruser Alpha One 3.0 Litre Digital Electronic Ignition
Numbers From The Breather Cover
Engine Seral Number 0F023390 the 6th digit could be 3
0F023890 the 6th digit could be 8
Outdrive is a Mercruiser Alpha 1
Sorry that this is a little long, however I wanted to give as much info as possible, thanks for reading
I started a thread in another forum, however I feel like this thread will be in the correct location for some answers, and troubleshooting, with patience, I have, time I have, money limited
I bought this boat yesterday for $ 1300.00 knowing that it could possibly have a busted block, from improper winterizing from the po.
The po has already been messing with the engine trying to fix it, however they gave up, now it's up to me to move forward with the troubleshooting, some engine parts were already removed and laying in the engine compartment
Major Problems that I know of, as of today after some troubleshooting, here are my findings thus far
1. Water mixed with engine oil, oil level appears to be normal on the dip
2. Water oil mix, appears on the rockers , and push rods
3. No rust on rockers or push rods as of today
4. The intake was removed by the po, I inspected it, and it appears to have some type of repair on the casting, rust inside
5. The exhaust riser was removed by the po, it looks rusty inside
6. removed all the spark plugs, they look to be original? and the gap looked good, the center electrode has little wear, creamic around the copper core looked normal tan, and the ground electrode looked normal, timing on the grounding electrode looked in normal range, didn't appear to have been running hot
7. The hex of the spark plug , and the creamic insulator has some rust
8. I attempted to turn over the engine wth plugs removed, to ensure that it was not locked up. I do not have a locked engine , but at this point it just means the pistons aren't seized
This is as far as I got with the engine today
Now for the Alpha one outdrive testing
I used the power trim just to test it, and it works, however it pushes out milky fluid out the cap vent hole when operating
I am not sure what is the issue with this. I feel like water intrusion also.
Question
What is my next steps in troubleshooting?.
I do have a lot on knowledge of auto engines, small engines, ect, however the marine engine troubleshooting is a bit different
I have compression gauge, leak down testing equipment, about 20,000 dollars in tools and equipment in my shop, that i have accumulated over the years, so i am willing to test, teat, and test
thanks for any help that all can provide. I appreciate...hope this will not be a junk block...
pics below may help some
Question
