Rose88
- Jul 10, 2019
- 49
Have a 5.7 New Engine and SE116 New outdrive. Just started to squeal pretty loud when engine temp gets to 160ish
Pulled outdrive back off and raised front of engine and aligned. (Damage may already be done)? It was off about a 1/8 of an inch. We used same engine mounts just bolted them to new engine. ( may have been out of align the whole time )?
Someone else put the outdrive in. Went out with old engine 3 weeks ago and somehow the oil drain hose from bottom of pan came thru the hull where the PLUG is suppose to be....SMH...and got in the prop and cut it off and drained the engine oil and locked engine up. Owner learned valuable lesson. Don't assume the plug is in or whoever worked on your boat said its ready.
Anyway customer brought me his boat and we installed a new engine and ran great for about 30 min on muffs and then this squealing noise started. Squeals in neutral or in gear but will go away at different RPMS. Going to get it warm to where it will squeal and pull outdrive again and crank back to see if it goes away? Really last thing I know to do. Have already removed belt and cranked and squeal is still there. When you shut engine off its almost like it still squeals after engine stops turning kinda like a turbo squeal. Maybe manifold leak? Any ideas or solutions please reply.
thanks!
thanks!
