loiner1965
- Sep 28, 2012
- 77
Hi
Second evinrude I bought as non running but other one runs great
This is a 1957 18hp electric start version ( no serial numbers or model anywhere etc)
Reliably informed on above by a marine engineer who's seen it and taken part numbers for approx year etc
Compression is 120 psi on both cylinders and renewed both coils / leads / plug caps and plugs
Points and capacitors are on way but she sparks great
Fully cleaned carb and renewed float / needle valve and washer and new gasket
Replaced all packing in the slow and fast jets...didnt remove silver metal disc and cleaned inside but carb is mint
Found an old manual on the net which states both valves should be turned in and back out 3/4 turn for starting reference
Points have been gapped 20 thou from the key on the shaft as reference and plugs at 30 thou
New fuel mixed at 25:1
It backfires and once I got it running rough but no more.....positivel the points are correct and even adjusted slow jet out but still no joy
Noticed the timing plate can move when franking over which seems a no no but cannot see anything amiss
Plugs seem to be getting fuel and will not start if fuel is inserted via plug hole which indicates timing
Baffled to say the least...
