Re: 1974 Evinrude 40 HP impeller change model 40455S
The pinion gear is captive in that lower unit, and there is no reason the shaft shouldn't just slide right in. Maybe the splines aren't aligning. Rotate it a bit while sliding it in. Or if all else fails, put it in gear to hold the pinion from rotating while you rotate the shaft in.
