Re: Can I convert my 55 fastwin to remote steering and throttle?
Well, is your boat set up with steering by chance? If not, then you have a bit of a project on your hands there. You can either set it up with the older cable and pully system, or the later style. I'll post ya some pics of some examples in the morning, if someone doesn't beat me to it tonight.
As far as the throttle and shift cables go, that's the easy part. Any OMC twin stick/twin cable shift box set up will work on that motor. It would be best to find the older Johnson Shipmaster or Evinrude Simplex Shift box set.
