vincep
- Jul 6, 2020
- 7
I'm having an issue where my engine won't run more than 1 minute. Installed new key switch, but engine will run for about 1 minute then cut out like starved for fuel. Person that I got boat from mentioned they disconnected the oil pressure because it wasn't working and to just mix the gas manually and run through tank. Is there a way to bypass the oil issue so I can rule that out as possible problem with engine?
93 115 OMC Quiet Rider model V115SLETS
