Dubvgogetter
- Jul 9, 2018
- 61
Hello everyone,
My 1992 Johnson 25 hp electric start would not start. I disconnected a wire connection by motor and it started with ignition. Wire was kill switch wire (black with yellow stripe). Motor will not shut off with ignition. i have to reconnect the same connection to kill engine. All grounds look good. Everything looks good around ignition as far as grounds and wiring. Am i wrong to think its in the ignition?
Thank you!!!!!
Thank you!!!!!
