Welcome Guest - Sign Up today
No announcement yet.
Honda 50HP - Cannot tighten Spark Plug in head. Head plug threads damaged...
  • Honda 50HP - Cannot tighten Spark Plug in head. Head plug threads damaged...
    The plug was incorrectly fitted and the now threads on head are damaged. I cannot get plug to tighten . Went in with force but blew out after an hour on the water.
    Is replacing the head the best option, is this hard, expensive to do ....
    Re: Honda 50HP - Cannot tighten Spark Plug in head. Head plug threads damaged...
    Will a heli-coil work? That would be my first choice. Will cause that plug to run warmer (because it's stainless instead of aluminum), so you may need to go one number cooler for that plug if the plug stays white, instead of coming up a nice tan.
    Paul
    Certified Tohatsu TLDI Technician
    Buffalo NY USA
    • #3
      Hi Paul
      I have been told that maybe a www.timesert.com would be a better choice . Does anybody have experienceof fitting these to a Honda 50HP ?
      • #4
        I've never seen the insert in the link you provided, but I don't see why they wouldn't work. Looks like a good idea to me and I'm going to make a mental note in case this ever happens to me.
        ________________
        2004 Voyager 18ft
        2004 Honda BF50
        • #5
          Have placed 2 helicoils on 2 cylinder engines because of repeted extreme overheats that damaged threads, works perfect, didn't need to change plugs at all. It's the least expensive work, probably will need to disassemble head so that metal bits do not enter cylinder while enlarging plug hole with tool to place helicoil insert.
          Happy Boating
          Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
          • #6
            Originally posted by Sea Rider View Post
            Have placed 2 helicoils on 2 cylinder engines because of repeted extreme overheats that damaged threads, works perfect, didn't need to change plugs at all. It's the least expensive work, probably will need to disasemble head so that metal bits do not enter cylinder while enlarging plug hole with tool to place helicoil insert.
            Happy Boating
            Very good to know. Seems like a cheaper fix then replacing the head by a whole bunch.
            ________________
            2004 Voyager 18ft
            2004 Honda BF50
            • #7
              Placed helicoils on both plugs but with cylinder head disassembled because the head was warped do to excesive heat, the machine shop did a impeccable work and after 5 years still working with no problem whatsoever. Both systems repairs threads, the tech difference is that one is a compact bushing insert, the other one a tough spring coiled bushing insert.
              Happy Boating
              • #8
                Originally posted by johnbwalsh View Post
                Hi Paul
                Timeserts are superior to helicoils for spark plugs because they are closer to the original heat transfer characteristics and allow you to use the original spark plug model.
                sigpic
                • #9
                  thanks for advice .. have sourced correct time cert kit and will attempt over next few days. Will post part kit details and photos if it works. Mechanic assures me it will last 10 years .. fingers crossed
                  • #10
                    The Timecerts worked a treat. Gave the engine two long run outs ...
