Welcome Guest - Sign Up today
No announcement yet.
Stalls when shifting.
  • Stalls when shifting.
    When I shift my Tohatsu todi 90 into foward or reverse it abruptly stalls like the prop is stuck. This happens intermittently. Any ideas?
    It's a TDLI 90 HP motor, right ? Does the display shows any code when doing that ? Does the prop spins freely with hand when at neutral and motor is OFF?
    Happy Boating
    Sea Rider 320, 380 Sibs, 450 Rib, 2 Strokes Tohatsu 5,18 & 30 HP Proud Smokers
    • #3
      What is your actual model? Is this a recent problem? What codes are in the ECU?
      Paul
      Certified Tohatsu TLDI Technician
      Buffalo NY USA
      • #4
        I will check codes when I get home. Prop spins freely. Sombody told me that the switch that momentarily stalls the engine to assist the shifting gears is bad. ????
        • #5
          2005 md90b
          • #6
            There isn't any such switch.
            Paul
            Buffalo NY USA
            • #7
              That’s what I thought. I am out in the sticks. Very limited cell no internet.
              • #8
                If you are loosing power on one cylinder due to fouled plug, plugged injector, etc., etc. the motor may well start and idle pretty good, but when put in gear/under load it could very well stall out......are all your cylinders firing now?
                • #9
                  Yes runs great. Good top end. The boat preformed flawlessly yesterday. It stalled one time shortly after startup. Great for the rest of the day.
