Eddie Rivera
- Feb 19, 2013
- 183
Hello, replaced float, needle, bowl gasket, and both small washer/gaskets on the screw holding bowl. Motor will not start. bulb gets hard and no leaks. motor cranks but wont start.
After changing the exhaust gasket and messing with float it started 3 times only till it died and never turned on. now i replaced the above mentioned items. but will not start.
I do have spark. I have 93 lbs of compression. Since i bought it in terms of the fuel pump, i only changed the rubber gasket on the sediment bowl of the fuel pump, but never tested nor changed anything else on it. It never gave me any starting issues till i messed with carb.
