MemoryMaker
- May 29, 2011
- 17
I just bought an 85 Bayliner Capri off Craigslist a couple weeks ago for $1500.
Pictures below?
When I test drove it, the guy I bought it from said that the low speed problem would be fixed if I fixed the skeg and prop.
I took my boat into the shop and had a new skeg welded on, the guy fixed my old prop, he replaced my impeller, and changed the fluids in the lower unit.
I took it out on the lake this weekend and I am still having speed issues. With 4 guys on the boat, I was only hitting about 15 mph at full throttle.
As far as RPMs, they stay around 2700 regardless if I am going full speed or idling.
Another problem I have is that sometimes it starts up right away and other times it takes a while to fire up.
What do you guys recommend that I do to address the speed, RPM issue, and starting issue given the following conditions:
1. This is the first boat I have ever owned and I do not have any experience working on cars or boats. But I do have some friends and family who could help me with repairs if I give them some direction.
2. I do not want to dump a bunch of money into this boat in order to fix these problems. I would rather just sell this one and get something else for around $2k-$3k that actually worked better. I would spend up to around $500 in repairs if I knew for sure it would fix the problem.
3. As you can see by the pictures, this is a decent boat (for the price I paid) but still is far from being in perfect condition. Ideally, I want this to be a reliable boat that fires up and can reach around 30mph. If I can fix these two problems, I will probably replace the old vinyl and carpet and buy a cheap cd player since it came with 4 speakers. But other than that, I don?t want to spend much more money on this thing.
From what I have read online it seems like it may be a good idea to start by cleaning the carbs and then synchronize the carbs and timing. Is that a good place to start?
Thanks in advance for the help.
See pictures below:
Pictures below?
See pictures below:
