Tilt Problems
kamboat64
1998 Force 120. Hit something on bottom of lake underway. Wasn't going very fast. Maybe 15 mph, but fast enough to knock the motor up on its tilt. So now, my tilt up doesn't work under power. Works fine sitting still in and out of water. Just not while moving. You can see it trying to tilt up but it moves slightly and then sort of falls back down. On trailer, I had my wife trim it up while I tried to hold it down. It worked great.
As always, all input and assistance is appreciated.
kamboat64
Thanks Jerryjerry. Gives me something to do next weekend. Hopefully this is the problem. I'll post results once I'm finished.
kamboat64
jerryjerry....which ones would this be in the attached pic. I don't want to order the wrong parts.
Would that be the seal that is part of the #10 assembly? Thanks again for all your help.
jerryjerry05
398188 Briggs and Stratton carb seal.
On eBay
I think about any lawn mower shop or small motor repair might have them.
