Re: Foam or not to foam
Yes, I cut drain holes in the stringers etc. and I'll be running at least 2 bilge pumps, fore and aft. I tend to double up on everything.<br /><br />Question is, do I even need to bother with the foam with a boat my size? Like I say, the factory didn't have it (not to say they built it right in the first place)<br /><br />I finally got the search to work right, and I have been readng the forum's past posts for a while, and it seems the foam is a big pain to use and keep dry. <br /><br />With the drain holes I have cut, I won't really have any 'air-tight compartments' per say. <br />The only thing the boat had originally is a 'double floor' (as I call it) above the stringers. The compartment is about 3ft by 5ft. One person said this may be for flotation?<br /> <br />The compartments were NOT airtight. In fact, nothing was. I don't know how you could make it airtight anyways.<br /><br />I like the coke bottle idea. I could stuff A LOT of those under there, but this boat is heavy! 26ft. Flybrindge? Has to be 8,000 lb. +? Maybe more?<br />How many bottles would I need to make a differance?<br /><br />H.
