install lounge seats
xGH0ZTx
I just removed an old seat I want to replace with a walmart lounge seat. I am left with four holes from the previous seat in my fiberglass floor. The seats will be delivered this week and want to be ready to install them.
What will I need to put these in?
xGH0ZTx
Re: instal lounge seats
these are the new seats...
Woodonglass
I'd fill the holes and do it like this...
Grind down the deck, use some 2x2 and Resin and CSM and tab it to the deck. Then screw the seat bases to it from the inside.
(Click the Pic to Enlarge)
xGH0ZTx
That looks like something I can do. What would you recommend I fill the previous hole with?
Thanks for all the help by the way
Woodonglass
I'd use Bondo Hair.
wambs8
I have the same seats.(wise????) Under the seats there are 2 plastic cross members that run from one side of the base to the other. You have the option of raising up the cross member enough that you can tab a 2 X 4 to the floor and use some fiberglass cloth over the 2X4's and then screw in some lag bolts into the holes of the plastic cross member and into the glassed in 2 X4.(carefull not to go into the floor). Kind of hard to explain. When you get the seats look at all the parts and how they go together and you will see what I mean. I was going to do it wondonglass way. I will see if I can get a pic to you.
wambs8
The plastic piece can be put into 2 different spots. The upper spot allows you to tab a piece of wood under this and screw into the wood not the deck.
Woodonglass
If that's the case them wambs8 is Spot On on his advice!!!!!
xGH0ZTx
That is SUPER helpful. These forums are great :)
xGH0ZTx
Before I fiberglass the 2X4 in do I screw it into the fiberglass deck? If so is there a certain type of hardware I should use or does it not matter since it will be covered in a layer or two of fiberglass.
Woodonglass
I would NOT screw into the deck unless absolutely necessary. the glass tabbing is plenty strong enough.
xGH0ZTx
OK I will just tab it in then. Is one layer of fiberglass enough or should I layer it?
I received the seats today and cleaned up the floor in prep for filling the old holes that attached the previous seats.
I am going to use the bondohair and then start working on the 2X4's. Does the would need to be pressure treated or doesn't it matter since it will be encased in glass?
Woodonglass
I'd use plain ole' douglas fir 2x4. I'd use two layers of tabbing. 2" tab then 4" tab. Make sure to wipe down everything with Acetone before applying first coat of resin. Coat the wood and the deck with resin and then lay the glass and dab it all wet using a Cheap CHIP Brush.
ezmobee
I did not know that and that's some great advice!
wambs8
I think Wise seating had a recent design change on the bases because no where in the instructions is it mentioned as a option to mount it this way.
xGH0ZTx
The seats I received are identical to the photo that you posted. There are no screw holes to secure the plastic piece in the upper position. I notice that there are holes to secure them if you were to use the lowest setting.
Will they be secure enough without screws?
Also I am debating whether or not to tab in two 2X4s to support each seat. There are two plastic pieces; however, the bracket in the front happens to be beneath the seat that is secured to the box which will make it very difficult to get at. Will one support be sufficient?
wambs8
Tab in 2 pieces of wood. One for the front and one for the rear. You can use longer screws to go into the upper position. But it would be better if you drilled from the bottom and into the upper part and used some small bolts and nuts to attach the black plastic to the frame.
xGH0ZTx
So predrill into the 2X4 a space to fit the bolts and just drop the supports onto the bolts after fiberglassing the 2X4 in...
Then prob just use some washers and nuts.
Is that how you installed yours?
wambs8
I did not install my seats. My vinyl floor is on back order. That lag bolt is really a lag screw. Your using a small bolt and nut where the black plastic support meets the frame because you wont be able to get a screw driver in there. Use washers and split washers where ever possible. Use all stainless.
wambs8
You can use these lag/screws if you want. Sink the screw portion in the wood and the thread part sticks out. That way you can use Nuts. So if you ever want to remove the seats.
